Newby 2000 787 fuel injected
rparker11
Just bought this 787 fuel injected I was riding it and it was running fine then it seemed like i sucked up a stick or something was caught and it wouldn't run over like 20. I turned off the motor and it wouldn't restart because of a dead battery. So I got it out of the water and checked the pump and nothing was stuck got a new battery and it started right up but still will only go like 20. Put new plugs in and it went like 50 at start then did it again and will only go 20 the one plug keeps filing out. Took the head off and nothing is wrong in the motor i don't think. But it seems to only be running on 1 cylinder. I have spark in both.
I also ran normal outboard 2 cycle oil for a few house (never knew seadoos took special oil)
Also the battery keeps going dead too (brand new battery)
Please help I dont want to take it too a shop
Solved
Anyone else that ever has this problem i ended up cleaning all the lines out. Drained the oil tank and cleaned the oil lines and filter and put new plugs in.
