Newbe, 97 GTX project, where to start
Greggl
I am new to jetskis and just bought a 97 GTX that has issues. I got it for cheap hoping to fix myself. I'm looking for a advice on where to start. Here's the situation. Seller said in 07 he was riding, running fine, and blew a fuse. He couldnt get it to stop blowing fuses so he gave up. He claimed it has 60 something hours on the meter but I havent been able to get power to the gauges yet. It sat out last season. I bought it and had a seadoo shop take a quick look. They pulled the rave valves to look at the pistons. One looked okay, the other scarred and gouges.They pulled the MPEM? cover and the 5amp fuse was blown. They stuck a new fuse in and it blew on insertion. Then they metered something and said the stator was shorted. They recommended a new motor. I then took it to another jetski mechanic to see what he thought. I told him what the dealer said. He checked compression. Bad cylinder was 30 lbs lower (120 lbs?) than one that looked okay thru valves. He pulled a wire harness from somewhere front of the motor and the fuse didnt blow on insertion anymore. I think he unpluged the charging system(stator). Then he tried starting normally. Nothing. Then he shorted across the solenoid? and it turned over but didnt start. He also found a broken fuse in the black box in front of the battery. He ran out of time at that point and I decided to take a whack at it myself as I found out long ago that paying someone to chase electrical problems can break you. He thinks it needs a new top end and a stator/starter/or start switch at a minimum. Where should I start. Any suggestions are appreciated.
Sorry , wrong forum
I just figured out I put this in a boat forum. If someone can delete, please do. I already re-posted in the PWC forum. Sorry.
