Hey all,
This morning I installed a new wear ring (aftermarket) and Skat-trak swirl impeller I got from Impros.com. My boat is a 2001 Sporter LE with the 155mm pump that uses the rubber seal instead of neoprene seal. Another thing of interest is there are two sets of 2 screws that hold the wear ring in place. I have never done it before but it seemed straight forward. Well now the pump is together and I have a couple questions.
1. The new wear ring just dropped into place like a hot dog in a hallway. I see everyone talking about hammering it in etc. That concerned me.
2. With the wear ring installed, I drilled a couple shallow holes and put the screws in place. (although I think I should screw them deeper) Now with the new impeller installed it does not turn smoothly at all. The issue is the impeller rubbing on the wear ring. If I insert the impeller tool and use a ratchet to turn the impeller, it will go, but with some effort. I definitely cannot spin it by hand.
I called Impro's and they said just check the set screws to make sure they aren't pushing in, otherwise it will "wear itself" in. I am thinking they are right, but I wanted to hear it from a couple other people before I throw the pump back in.
What do you guys think?
Here are some pictures
Set screws
Set screws
