New way to CLEAN inside Hull
bigbaldbob
I found a great way to clean the inside hull.
1. replace all grey fuel lines.
2. Forget to connect large hose from fuel tank to filler neck.
3. Take Ski to gas station.
4. Have friend start to fill up ski while your filling up another boat.
5. Friend should ask's how much fuel does this thing hold after pumping 20 gallons of premium into bottom of ski with out pump shuttin off.
7. Drain the fuel and admire how clean the hull is now.
Thats how my weekend went. :cheers:
Wow! And what COULD you do with that fuel after it is drained out?
Let's see what would be in it if I did that with my XP...2 spark plugs, a spark plug wrench, 1-1/4 lbs beach sand. 3 broken stainless hose clamps, and at least 6 still in good shape. Not sure how to measure the salt in there, I would guess at least half a pound. A couple smallish chunks of old grey fuel line. :reddevil:
You should be set for starting Bon fires for a while, huh? :)
scooper, that's funny.
