I wish I could give you objective, comparative info on the impeller.
I purchased my '96 Challenger with a locked-up engine. While the engine was off at SES being rebuilt I looked at my jet pump and found that it did not rotate very freely, needed a wear ring and steering nozzle replacement, and appeared to have the stock impeller.
When I priced the pump rebuild kit, wear ring and new or even used Skat impeller, the total was higher than what I found for a recently rebuilt jet pump with the Skat 17/22 already installed from a guy on ebay that parts out LOTS of machines. So, I opted to just buy the one that was already done.
On my GTX I couldn't find such a deal, so I bought the parts and did it myself, and added a used aftermarket impeller to that one as well.
Anyhow, the original impeller is still in the original jet pump which has not been rebuilt or re-installed. So, I don't know how the boat does with the stock impeller.
What I can tell you is that with the 17/22 Skat and my engine running poorly due to an error I made in the engine installation after the rebuild, with 3 people on board (about 500 Lbs), a FULL tank of gas, and less than an hour on the engine, the gps on my phone indicated 48 mph. And yes, I have since read the engine break-in directions and realize that I should not have been doing any full throttle runs that early in the engine break-in.
A touch of background: Because of the error I made installing the rebuilt engine, it lasted only 2 hours before the pistons melted. I sent it back to SES to be rebuilt again and just got it back this week. Installed it on Monday, first test ride was Tuesday and we had about 300 Lbs of people and had only burned a gallon or so from the full tank of gas. First step of break-in is 10 minutes of idling, then 30 minutes of varying rpm, never to exceed 20% of throttle, followed by a cool-down period. Second step is running at varying rpms up to 50% of throttle.
A nice surprise!
I have read other folks with similar single 787 engined boats needing to get into the throttle quite a bit to get on plane, even when they have good pumps with servicable wear rings and no known air leaks. At 50% throttle I was on plane in probably less than 5 seconds. I was able to stay on plane as low as about 35% throttle.
I really wish I had experience with the stock impeller to say whether this is common or not, but the impression I get from other folks on the forum is that I would not have been able to get on plane at 50% throttle with a stock impeller, and would not have been able to stay on plane down to 35% throttle.
I haven't been able to run the boat at full throttle on the latest rebuild, but hope to this weekend. I'm very eager to see what kind of performance I get with just me (about 200Lb), and with the whole family (2 adults, 3 kids & dog, totaling about 600Lbs, plus gas... geez, we can only carry about 6 or 7 gal and stay under the placarded 650 Lb limit).
