Hi as the title says I'm completely new to seadoos .im more of a mechanic than someone that plays with these thing Sadly, but right now I'm working on a 96 gsx that's got electrical problems . The owner winterized it at a dealer and stored it for the winter , pulled it out this summer and it's doing the following: starter keeps cranking as soon as you connect battery power and will fire up only if I hold down one of the vts buttons . Vts works though.
Traced it to the point where if I unplug the two wire plug on the solenoid it will stop cranking . Also checked the start button which is good could it be the mpem? Or even just the diode I've read quite a bit about on here ? Could the mpem also cause it to not run without holding the vts button ? Can someone please guide me as to where I should post this please...
I'm way better at mechanics than wiring I need all the input I can get .
Thanks in advance, lots of good info on here, love it
