Hi,
Just joined the site and I'm hoping for some help/advice. I recently bought a '97 Sportster and after getting it cleaned up took it out yesterday for the first time and not everything worked as well as it should. I don't know much of the boats history so this was sort of a shake down ride. Here's a rundown of the problems:
1. The starter will not engage/turn every time the button is pushed. Sometimes it clicks, sometimes there's a clunk, sometimes it engages and turns then goes zzzzzzzz, sometimes it engages and turns like it should.
2. When the starter does engage the engine fires right up but when I took the boat out it would not go faster than 10mph and after half throttle the engine seems to bog down and has a bit of a miss. Pull back on the throttle and it smooths out. It has new plugs but that is it.
3. Gas gauge doesn't work.
4. Bilge pump won't run when I turn the switch on.
5. Water comes in through the drain hole below the driver seat when the boat is stopped, runs back out when it's moving. The outlet just has a flap on it, is there a way to keep the water from coming in?
I believe that's pretty much it for the moment. Hopefully it won't take much to get it straightened out.
Thanks in advance for your help!
