Hey all!
First post here. I was given a 2008 Speedster 150 with the 155 NA engine.
It has about 540 hours on it (I know), all freshwater use, and believe it or not, the previous owner had it since 09.
I put it in the lake to give it a run around and after letting it idle for a few minutes, it came off the trailer and ran in a way that felt great.
A few minutes into my ride, it gave a single, random, loud beep that lasted maybe 2 seconds. Then a few minutes later, it came on with a continuous beep that wouldn't stop, and the oil light started blinking. The engine had severely reduced power and sounded kind of weird after this happened. Made it back to the dock. Took a look down in the the impeller and it looked fine, nothing stuck in there.
I checked the oil level and it seems fine. The gas is, at a minimum 1 year old, but it could be 2-3 years max. I siphon'd all that out and am planning on filling it up with some fresh 93. I also bought new plugs for it, since for $12 it can't be a bad thing. Those are coming tomorrow. Is it right that the plug socket is a 5/8 deep socket?
The other issue is that it needs a new bumper trim/rubber rub rail. The current one is sagging and falling off. SeaDoo doesn't sell this part anymore, so I am trying to find an alternative replacement. I found this, but don't know the proper size, anyone have a clue on this? Vinyl Rub Rail Inserts TACO Marine
If anyone has one somewhere, the OEM part no I need is 204050463
Other things I am planning on doing: Replace ladder rubber latches (they're gone), so the ladder is just hanging out the back, polish out the whole boat and detail it, repair nicks in the gel coat on the front, replace ignition coils as preventative maintenance, new air filter, reupholster seats, replace the speakers, install a bimini top. Right now it has holes in the hull for the OEM Ski Tower, but that wast not included. If I could find an OEM Ski top and install a bimini top on that, I would, but it seems hard to find and expensive, so I think I'll need to go for an after market top and then just have those holes patched. Also plan to replace the front red and green lights with LED's and replace the OEM speakers, as well as the OEM headunit with something that supports bluetooth.
