Jaiello
I just bought a project 2001 seadoo xp. Long story short. Got the jetski for a a few hundred bucks. This is my second time owning seadoos. The other two I had I had zero issues with. This one I bought as a project to work on. It has the 951 engine. The previous owner said it had low compression on one cylinder and it would surge up and down. He rode it back to the dock and left it. He said it needed a top end. I said what the hell I am handy and have had and I own a boat and have worked on many engines. Well that was a load of you know what. The true story once I cracked open the engine was a disaster. One of the pistons looked burned. After looking more into it. The piston rod is bent and all the pins for the Bering where on the bottom of the crankcase. The piston rod moved up and down and wiggled. I have no idea how he can say he rode it back bs. Anyway, ordered and installed a new crank with new pistons, and all new seals. I am waiting for the cylinders to come back from the machine shop to finish and get it in the water. I had to go .5 over on the bore and pistons. My questions are as follows:
1-Do I have to trim the rave valve with only .5 over ?
Some say I do others I don’t.
2-Anything I need to do besides premix the first start up?
3-Also anyone knows where I can get the rubber that goes around the gauges ? Mine are trashed being as he left it out in his yard (I had to sand it down 800,1000,2000 then rubbing compound then polish then wax. It looks new what a pain
4-Any suggestions on draining the gas tank without removal? Gas is at least 8 months to a year old.
5-Also what should I do about the carbs? I really do not want to rebuild them since it never turns out right. At least everytime I have tried on every engine it makes a mess of getting things tuned right.
Any suggestions are welcomed this type of forums are invaluable to people that work on their own stuff. It wouldn’t be fun unless you can tinker with your toys
