Hi all,
So I started out to fix a 'low 12 volt' problem on my 1997 GTX. Turns out the stator was shot so I picked up a new one that came with the pick up coil and the plug etc. The engine ran perfectly before changing the stator and pick up. Now it has no spark at all. The pick up coil resistance tested out correctly before I installed it. The only thing I can think of is the gap between the pick up coil and the mag cap is too big. I checked the new one to the old one prior to install and they looked identical but maybe a tiny difference is enough to mess it up. The problem is it is impossible to measure the gap, or adjust it as far as I can see. Is there any way of actually measuring the gap? If I have gone from a good spark to no spark and all I've done is change the stator and pick up it seems like it would have to be something with the pick up because I don't think the stator has anything to do with spark but I could be wrong. Is there anything else I should look for?
Thanks if you have any advice.
Bruce
Bruce
