spewing oil
Not having much luck with search. Bought a 3up spark and essentially got a working 1998 GTX Limited for free. Silver 951 w/ carbs. 400+ hours, it was rebuilt in the 10's at some point. Visual inspection shows replaced fuel lines and the diaper in place. Nothing loose, obviously missing. Previous owner switched it to pre-mix. Choke is disconnected. Oil pump cable is disconnected, hanging loose.
Starts right up but smoked heavily. idle was 3400
I drained out old gas and put new gas with XPS synthetic 2 stroke oil. ~38:1
Started for a bit, Still smoked.
Pulled and replaced plugs with the br8es 3961 ngk solid. Old plugs were nasty
Reset low speed screws to factory spec, one was way off
idle was low so reset via screw to 3000 rpm. (out of water)
Still smokes pretty bad. I wanted to ask before I leaned out more with the low speed screws. Any input would be appreciated!
