devonte007
Plugs are really easy to change, just get yourself some dielectric grease, and anti-sieze lubricant. Each of the cylinders have their own coil packs just like new cars these days. Do one plug at a time, unplug the wire connector from the coil pack, then just pull the whole coil pack straight up and out. Next take your spark plug socket and remove the plug.
To prepare the new plugs, gap them correctly, then remove the little nut cap thing on the top of the plug (necessary for them to fit into the coil packs, as you will find the old ones when they come out). Next apply a bit of dielectric grease around the white part of the plug where the rubber from the coil pack will sit, and then apply a little bit of anti-sieze lubricant on the threads of the plug and reinstall everything. I also like to apply a bit of dielectric grease to the coil wire connectors if there is none visible, helps keep water out and prevents rust and corrosion on the connectors. I like to apply these lubricants to boats since they are constantly in a moist environment, and the engine head is aluminum; piece of mind I guess.
Also, in case you do not already realize this... if you become a premium member to this forum you can download the shop/service manuals for your boat and motor. Seeing as you like to take on these projects yourself (like most of us) the service manuals are invaluable, and a good read to understand how these engines work. I have spent many hours looking through the manual to help me understand the peculiarities of these boats. Ok then...
