shootawave
okay finally looked at a schem for my jet pump. the imp housing will move until it it held back by something directly behind it (the impeller shaft is still in) if i pull harder it is pulling the (inner output drive shaft??) out of the engine i can see the spline, schematics do not show a retainer clip. do you have to remove the impeller shaft as it seems that it is seperate from output drive shaft. this shaft if rectangle square at the end, maybe for a reverse thread? The output drive shaft has a collar that does not move and will not pass thru the hull bushing. (I wonder if this was the cause of the water in my hull as well) I hope i am explaining this correctly and just cant figure it out.
