I have 2003 Utopia 205 optimax 250. Original Rule 500 pump started acting up, I cleaned it up and now will not turn off. I installed a new one (wired correctly (ground to ground, brown and white to brown and white, solid brown to solid brown. ) The new pump does the same thing just runs. Even with the float in the off position.
I tried it with only the ground wire, and brown/white wire connected, the switch on the helm does not turn it on and off. I pulled the switch and tried replacing it with the light switch that works and no luck.
With both pumps acting the same It has to be something with the wiring but I can not figure it out. Do the switches ever go bad? Or maybe I need to replace the fuses in the switch.
Any insight would be greatly appreciated.
Many Thanks,
Jason
Many Thanks,
Jason
