henryb
Yes... seadoo puts a buzzer in on all their toys. The Merc boats have 2 buzzers. One is in the Merc harness ad will give you warning on the oil, water in the fuel... and so on. The Seadoo buzzer is for low voltage, low fuel, and TEMP. BUT.. the quality of the seadoo buzzer is just OK.. and on anything over 10~12 years... you can count on it being dead. I've personally changed it out on EVERY used seadoo I've owned.
That is just exactly the info I was looking for... Thank you very much Tony... I will see if the tech can swap in a new buzzer tomorrow.
BUT... on the Merc engine... there is 2 temp senders in the engine. The port side is fed into the computer, and adjusts things. (even on the 210 carb engine) the one on the starboard head isn't hooked to anything. AND... it happens to be the tan wire up in the helm. (not hooked to anything) You can put a temp gauge in easy. Just get one that is compatible with a Merc outboard... and hook it to that wire.
Sounds like a much more valuable gauge then an hour meter, I will see if they have one in stock and will install it myself. Thanks again!
