henryb
Just bought the boat this weekend. Took it out on Lake Ontario on Father's Day, had a great first day with it. It has some small issues that I will have to address, but overall it is a great boat.
The reason I am writing to this forum is because after about 3 hours on the lake, mostly at cruising speed (25mph) or slower.... as I was idling back into the boat ramp, about 3' from the dock, the engine stalled out. We were so close to the dock, we just drifted in nice and slow. However, when I went to restart the engine to manuever into position for the trailer, it would not start? The boat did not come with any manuals, specifically the M2 Operators Guide, so it was all an educated guess on starting procedures.
I was thinking that maybe the plugs were fouled as the gas was from last year, the tank was almost full, so I didn't want to try and drain it out? So I pulled out one of the plugs last night, now that it is up on the trailer and in my garage (kind of a hard place to dry start it)... but the plug looked to be brand new. Maybe I need to pull all of the plugs and check them.
Without any manuals, I don't know if there is a auto-enrichment or choke, not sure how that function works. I did notice last night that the ignition key does have a push function that is commonly used for an electric choke. But I could not activate it, with the key in the ON position.
I had a hard time finding what the correct plugs are for that engine, but eventually, I found out that they are supposed to be NGK BUZ8H. It is the carberated version of the M2. The plug that I pulled out was a Champion QL6VC... from a quick search on the net, it is the Champions match for the NGK BUZ8H.
I will pull the trailer out of the garage either tonight or tomorrow and see if it will start. I understand that the white plastic garden hose fitting over on the starboard side under the engine cover is a fitting to running water through the engine to allow dry starts for longer then 20 seconds.
Any guidance in resolving this issue would be greatly appreciated.
Thanks,
Brent.
Thanks,
Brent.
