bryceheinz
Just bought a islandia with a 240hp mercury engine. There is a hole in the block. What are my options for other engine swaps to replace it? Any shops I should use should I choose to have it rebuilt?
I get alot of guys rebuilding there older machines.im finishing up a 98 spx right now fuel system rave valves and bellows went thru the pump motor has perfect leak down.his bill is 2200 bucks and he is happy as a pig in slop.got a fun good running machine for a 1/16 of the price of a new oneThe way I look at it would be not what the boat is worth but how much to replace the boat.if it's clean and the pump etc is good I would pull the trigger.then you know you could get another 20 years out of a 4000 dollar repair.
Where is the boat located and how much you want for it as is?Unfortunately the power head is more than $1,000. My boat would be a great project if you provide your own labor - I guess its not too hard to swap out engine, but I have no garage to pull engine. My jet boat would do 50 mph easy and it gave me and grandkids great fun for 10 years.
Shoot me a pm with some pictures. I’m in ClevelandComes with excellent Sea Doo trailer with replaced tires and rims, boat was analized by Mercury Dealer and winterized. Located next to Albany New York. $1,500 or best offer. I have not advertised yet. Lots of pictures if interested.
I can do the work. I should have stated that I was more so looking for an engine supplier vs a shop to do the labor. I’m a diesel technician for a living so this little 2 stroke is easy. I have it inside my heated shop as well. I saw reman engines around 6k but that’s more than double what I’d expect a long block to costAny merc dealer can get you a remand block.i would go with the same 240 efi as the blocks are all the same that would fit.your trouble is going to find someone to do the work.what state are you in?
I sent you a pm with my phone numberSo here are pictures of my boat for sale. The blemish on floor has never been a problem. The stiching on rear seats has come apart. I did see refurbished powerheads on Ebay for less monies than $6.
the hole is in the top of the piston. the cylinder bore is ok.
