Hello guys, thanks for taking time to read my post
Last weekend I took my 2005 Sea Doo Speedster 200 SC (370hp) to Lake Havasu Arizona. The temperature was about 109 degrees (F). After about 2 hrs of riding I turned it off to jump in the water then turned it right back on and the hi temp lights beeped. I removed the lanyard and everything went back to normal. Continued the rest of the day with no problems. The same thing happened the next day. No problems after removing lanyard. Should I be worried or is this normal due to the hot weather?
To be on the safe side today I removed the J-pipes and flushed the 3 holes with compressed air and the hoses, to remove any possible debris/sand. Is it normal to have a small water leak between the the J-pipe and the water box main hose opening when flushing on a garden hose? I have never paid attention in the past and saw a small leak today while flushing the engines. Leak is out of the hose opening not a hole on the hose. Maybe due to hose water pressure? Any advice/help will be greatly appreciated.
Thanks
Thanks
