WaterChampion
Soooooo... I forgot to strap my battery down with the bungee cord.... hit a good wave and boom... power out. Took the seat cover off and found the negative terminal screw was barely on (as soon as I touched it it fell off). I’m wondering if this is what fried the MPEM, or if it was the positive terminal hitting the front stator cover maybe? either way I kept blowing 5 amp fuses. To diagnose, I simply put the troubled MPEM in a working ski and it blew a 5 amp immediately. I decided to do MPEM diode surgery with no chemicals, only an Exacto knife and some custom dykes. I was very careful with the Exacto knife and used it safely, ironically though, I cut my thumb while pulling wire connections apart to get the MPEM out...
Yes, those are drops of blood on the wire connectors... once out, I proceeded to cut into the MPEM
I just kept carving away until I exposed both ends. Then I put some dykes on a grinder wheel to make them really pointed to snip the leads as close to the diode as I could.
Next photo shows the right lead clipped apart, left lead still attached.
Clipped both leads, then I used the dykes to rip out the now unattached diode.
This took about 2 hours total. Next step is to extend the leads with some solder and wire and make the new diode sit out of the box. I’ll probably cover new diode with some tube silicone. Will update. Not sure if this will work or how it compares to other people’s diode replacements but I’m happy with what I have so far. If you attempt this method be careful, Exactos are sharp.
