Mine is a 99 speedster does anyone know if I’d has the limp mode when overheating?No such thing as limp mode on a 95 Speedster.
I was thinking that , so I unplugged them but the beeping still continued , also didn’t change my rpms on both engines .
Had it at the shop today , the mechanic said that he wasn’t getting any alarm while testing today. Strange !Look at the switches, lower right, it's amber. Is it flashing when the alarm is on????? If so, you're low on gas. Toggle it and the beep will stop. If the light isn't on toggle it any way the light might be bad. That is your reserve, time to get to the dock!
I checked the voltageThe beep is a condition set by ty the sensors. Low oil pressure or over heat set the a alarm and puts the engine into low rpm to protect them. The sensors a are dirty or it’s the old style or the voltage on the charging system is low setting funny conditions with the computer. Check voltage replace both sensors I lived it !!!!
How did you come to that conclusion, also what do you plan on doing ?Well I found out that the mpem was bad on mine..
Follow up: He dialed in the mixture and says it runs fine now.Exactly the same problem: one engine can't make it past 4000 in the water. It'll go higher out of the water, but stumbles and coughs like crazy...
I’m thinking I may do the same , still trying to trace where I’m losing voltageWell what I am doing is just selling this piece of shit the way it is and getting rid of it
How did youI’m thinking I may do the same , still trying to trace where I’m losing voltage
Strange thing was it wasn’t on the engine that I had a problem with, so checked both sides !The red wire which goes to the 15 amp fuse. Checked for continuity on all wire going to and from the charging system . The red one was fried along with the harness . Cut the harness off added a in-line fuse working perfect .
