Without the bumper, I have seen shafts spin as they are not in the correct alignment in regards to depth.
here are some picsRemember this is a custom application. Not your normal oem bombardier driveline and engine package. Adjustments are going to be different since you have a different engine etc. Let's get some more detailed pictures up of the boat, driveline, engine, couplings etc.
Plus we want to see more about how this was constructed and if it is an efficient combo/swap.
Rob
Rob
Did not find a bumper in there....BUT I did fish out 2 small washers covered in grease. Im going to take off the allen head bolts and see if its "stuck" in there.
How hard to align motor? I never ever tried it or know anyone who has attempted it
I'll consider the PTO and back OEM, so bumpers, end play and alignment still should work like the original set-up.
I'll assume they used the washers like shims instead of the bumper. If everything lines up, to quickly add more tension to the boot/carbon seal you can loosen the rear hose clamp and push the boot towards the PTO and put a cable tie around the thru hull fitting. (See yellow cable tie in pic) Thanks Manolocross for the pic
Yes...."that"
That retaining ring is blue plastic, correct? If so your fine.
