jammin seadoo
Hello, I am looking for some help on my 2000 challenger 1800. It has the 210 carb engine. I started acting funning last year it died and would not restart for about 10 minutes and when it did it would die as soon as I got into gear. Then all the sudden ran fine.
Now this year had it out 6 times and then 7th time would not start. brang home and checked have no spark on all cylinders. ran through diagnostics and found outer switch box circuit of stator is open. would this cause it to no start or should it still run on 3 cylinders? also temp sensor with one wire test open circuit as well, this should not cause engine from starting should it? I can say no spark at all
where should I start? PLEASE EVERYONE RESPOND:cheers:
