Here is what it's doing or not doing. OK, it will turn over and crank up sometimes! If the kill switch is on the post, and you go to crank it with the start button, it may turn over and crank right up or it may not turn over. If it doesn't, you can take the kill or key (I call it the Key) off and put it back on and try again. I may have to do this once or maybe 100 times. Once it turns over and you leave the key on, it will ussually crank, unless it sits there with it on for more than say 5 or 10 minutes. The sea doo dealer in my area can not figure the problem out either. He has checked the post, the key, the start/stop button, and the computer. He said he spent hours ohming out the wires, and still can't figure this out. Once you get really frustrated and tired of taking the key on and off and trying it, and you just let it sit for 15 or 20 minutes, you may go and put the key on and it will crank right up. You may not think this is a big problem, but it is absolutely the most frustrating thing I have ever seen. I have another ski just like this one that is not running do to a bad engine, and the dealer switched out several parts from this ski to the good one and it is still doing the same thing. I can take a screw driver and turn it over across the solenoid and all it will do is turn over and not fire. I let it sit and forget about it for a while, and go back to it and it may or maynot crank right up. This has got to be some kind of bad wire or computer issue. The dealer said he swithced the computers and that both computers are good. CAN ANYONE HELP ME?
