Moisture content?
I find that very interesting, since most people don't even consider "delamination". It isn't something you typically see with our boats or skis.
The occurance of delamination occuring on your behalf is practically nil, from what you've just stated. So, that leaves manufacturer defects. I would almost bet this is fairly common since 90% of the population would not think of something like this, to a boat that is not left at dockside.
Delamination occurs when the glass fibers begin to seperate, allowing water to seep in and continue the process to the point that the hull will loose it's integrity, eventually failure and sinking.
It's not uncommon to see this in outboard boat transoms. Anywhere you drill a hole through the fiberglass, you set yourself up for the start of delamination. But what I find unique in your thread is, we don't leave our boats in the water and if 90% of the time, delamination in fiberglass is caused by water, how is it getting between the layers of fiberglass with a solid gel coat. If you leave it in the water, then you have barnnacles and other marine growth that can penetrate the hull and start this process. But, not from just normal use like you pointed out. If this has truly happened in your instance, it's not somthing you did. It would obviously be from a defect in the fiberglass during molding.
With the price of the newer Seadoo's reaching into the $50,000 USD, I guess protecting your investment with the moisture meter would be to your advantage. I have been in boats for over 40 years and have never had or seen anyone use a "surveyor" before buying a recreational boat. I can see it if I were buying a million dollar yacht, but not a jet boat. Of course, this is only my opinion and experience living in the southern U.S..
I would be curious about this surveyor that found this big spot under your hull. I would also want to test many boats to form a base line. I don't think it's possible to have a 100% moisture free environment, on Earth anyway.
If you've seen a hull being made and formed, then the glass being attached, you can see where they would almost need a vacuum type atmosphere to make sure they had 100% moisture free glass. Any tiny air bubble that go un-noticed, could start the delamination process. So, that would lead you to believe that these builders are certain there are no air buddles in the resin.
This is a really deep subject and in your case, a very important one. In all my years, I've never seen a concern to the degree that a special meter was needed to protect or get a sale on a sport boat. I've been here now since 2007 and you are the first member to ask this question. So, it's really not something a lot of people with our Seadoo's are concerned with. Now, go to a sailboat or yachting forum, I'll bet you see a lot of comments or people looking for information about this subject.
Thanks for the update and input. I hope you use this device on many boats, even new ones to see what kind of moisture percentages you come up with.:cheers:
