henryb
I just installed the new gas tank sender unit, as my gas gauge was not working. Gas gauge is reading properly now! Also noted that the low-gas level buzzer is also working! The Seadoo Operators Manual says that it should indicate that there is about 10% left in the tank... well, it buzzed with about 1/4 tank full? Well, that is not such a bad thing, but what was worse, was that the Low Gas Buzzer Shut-off switch (on the dash with Orange light) did not seem to shut the buzzer off? The Orange light came on ok, but it would not shut the buzzer off. I filled up the tank with another 20liter can of gas and then turned on the ignition, sure enough the buzzer stayed quiet.
I checked the fuse for the switch, looked good, but I swapped it for the only other 3A fuse on the Nav Lights. Didn't seem to help. I also checked for continuity on the switch connections... the schematic shows that the switch closes the connection between the 2 black wires. So I checked 12v between the blue wire and one of the blacks... good. Then tested the blue with the other black it had 0v, until I pressed the switch, and then it would have 12v... so it appears that the switch is working?
Any suggestions on where to go from here?
Thanks
Brent.
Thanks
Brent.
