sony224422
So, I had finally rebuilt my top end and got everything buttoned up and running. I broke it in using SBT's new engine break in period. I premixed and used the oil injection. I also kept the RPM low through out the first tank of gas. She ran beautifully. Now, on about 2-3 hours, I lost power after jumping a couple wakes and barely limped back in. I took the plugs out, and they didn't look horrible, but it wouldn't start unless the throttle was about halfway and alot of cranking happened. So, i took it home, took the plugs out again, and got 120 PSI on the first cylinder and 40 on the rear. The top end rebuild was from SBT, it was the top end kit. New pistons, head and everything. I took the dome off and The first piston looks beautiful, like it should. The rear, no visible damage, no gouges on the wall.. and i can turn the engine over with little resistance. There is however, like a gray matter on my dome and on the walls and piston itself. I still can read the .05mm on the piston and see the arrow as well on both pistons. Def has no time on it. Now, i am thinking theres something wrong with the rings.. SBT didn't send directions and i assumed the rings were the same. Is this not the case? Or am i having other problems. I will host pics in a second as well.. but i would like to get this figured out. I've never seen anything like it, but i've only really rebuilt seized motors. Original cause of the rebuild was because the previous owner broke the drive shaft and let water in and sucked it through the carbs and let it sit on the pistons seizing them to the walls.. no other damage. I cleaned the carbs well so i thought, but now im not so sure.
Pics http://s11.photobucket.com/albums/a200/sony224422/jetski/
