Glue.......
I don't recommend glueing the wear ring in the pump housing. I only suggested you use silicone because if your intent on glueing, the silicone would let you remove it for future replacements. If you used epoxy, you'd end up replacing the entire housing.
As for SBT OEM certified. I've used them for 4 years now, mostly on Yamahammers but have never gotten one part out of specification. I do know, from experience with the distributers over the phone, if the part you receive is not in tolerance specifications with OEM, they will replace it with a new one. I'm not saying that mistakes can't be made, they can. I'm only saying that they will at least back up their claim of guarantee......
The core charges are usually the number one complaint. You'll see a member that has blown and engine, busting out a piece of the casing and being charged extra for lack of a usable core. This is common but if you read their core policy before ordering, you'd see that in writing before you order.
The moral to the story is: Always read instructions, contracts and return policy before purchasing anything. And when at a Seadoo repair shop, always ask for an estimate and when given, specify that they not go over a certain limit and if possible, ask for the damaged part. It would be best if your taking it in for a specific reason, that you scribe a mark on that specific part so they don't charge you for something they did not do. They can tell you they did and show you a part but that doesn't mean it came off your engine............:cheers:
