Mister Magoo
I have a 2007 Speedster 150 with what the display says as 15 hours on it.. Got it last year right before it got cold and took it out once and seemed to run fine. Got up on a plane, did not leak water, went to 7000 RPM's. Stated reading here, so I winterized it and looked at the wear ring and impeller. Wear ring had some grooves in it and the impeller had some nicks on the leading edge so I figured I would replace them both. Tried to buy a wear ring/impeller/tool package from PWC. They sent me the incorrect impeller and tool. Long story short they said they did not have a kit for my boat and recommended a Solas SR-CD-11/19, which, I bought from them. Put it on over the winter, no problem, seemed to be the correct fit.. Started just fine on the trailer. Went out for the first time since the rebuild today. In the water at full throttle only 3000 RPM's and goes no where. But, when I get it out of the water and onto the trailer I started it and it goes to 7000 RPM's. Did I maybe do something wrong reassembling the pump, I have and used the Seadoo manual on the rebuild and it was pretty easy. Any thoughts? I was thinking of putting the old impeller back on. Is the Solas SR-CD-11/19 correct? Thanks for any help.
