500whp335i
Hey Guys! Long time since ive been on here! I sold my Challenger 1800 over 3 years ago now to a friend of a friend. Long story short the guy has called me because he cant find anyone to work on the boat and he needs some help. In the spring I actually serviced the boat for him (spark plugs, filters, ect) and it started right up. This past weekend he went to go out and the boat wouldnt start. It cranks strong but wont turn over and start. I went over to take a look and found the high pressure pump connected to the motor ticks and works as intended. The lifter pump in the fuel tank is not working. I checked the voltage and it is only getting 8 volts... I tested the voltage from the positive right to the negative battery terminal to rule out a poor ground. I was only able to test the voltage when the key was turned once to "on" or when the fuel system primes its self.
Any idea what the voltage is suppose to be when the pump is priming? It could be only 8 volts to limit the flow or else i need to start finding where the wire comes from and check for a bad fuse or relay. Thanks!!
