I just had a motor installed but the noise was their prior to that,you can only here when in the water and sounds like in the pump area,pulled the pump and took it to the dealer and he said the bearings were fine and ask me what the idle was set at,1350 i told him and he said to low and i adjusted the idle to 1500 in the water and the noise stops but when you shut down just befor it stalls you can here the knock still faint but still there,i need help please,it was loud enough when the idle was low if you were idling together thru a no wake zone you could here it
