Surge breaks?...
Though it's probably nice to know you have them if you need them, I don't think there necessary for a boat that size.
Usually, you only see breaking systems on the heavier boats. I was kinda surprised when you said the trailer had surge breakes. I'm not to sure of the weight but if it's less than 4000 lbs, ...I think you'll be fine. The idea of the better axle and tires is worth the security. You'll probably notice a big difference in the way the trailer handles with that set up.
I've had a bearing seize on a boat trailer for a friend while I was heading out to the river with him, to try and help figure out where to sit the motor and whether or not, trim tabs would be necessary (not a Seadoo). The parts to the trailer axle was literally bought at Walmart. You'd be surprised how cheaply boat trailers are truly made. Especially when you can buy the parts off the shelf. The spindles are about 14" long and slide into the thin walled material of the axle tube.
If you had a surge breaking system, I'd bet your trailer is a bit better than the "el cheapo's" they sell us here on the Gulf Coast........:cheers:
