Sportster-2001-951C-Stock
Sometimes in my opinion monetary value is outwayed by the happiness and potential joy you will get from it.
Absolutely, just go price a new boat if you're feeling $$ pain.
So we took the boat out for a campout this weekend...it is guzzling 10 gallons per hour which is twice what it should be burning, so it is going back to the dealer to find out how to fix that. Initially it was only topping out at 42-45 mph which probably is not as fast as it will go either, so hopefully fixing the gas guzzling issue will also give me more performance...we will see what mechanic comes up with.
I don’t know these engines fuel consumption but 10gph seems adequate for 210-240hp. One thing I note on mine is the fuel gauge will read empty with 3/8-1/2 tank still left. My carver has twin 350cod small blocks propelling a 20k on boat on plane and I am about 30gph for both engines.So we took the boat out for a campout this weekend...it is guzzling 10 gallons per hour which is twice what it should be burning, so it is going back to the dealer to find out how to fix that. Initially it was only topping out at 42-45 mph which probably is not as fast as it will go either, so hopefully fixing the gas guzzling issue will also give me more performance...we will see what mechanic comes up with.
Don't know why some say parts are hard to get-- Merc has been using that engine for many years on their outboard (except the crank). I have the same boat and engine, can find any part I have needed. But they are EXPENSIVE.
Most Merc dealers won't work on them because they are hard to work on. Sometimes standing on your head almost.
Which fuel pump?
There are 3.
Thanks for your quick reply
That’s is probably the beginning of my mystery!
I am not sure, here’s a snap shot of both sides of my motor. Does this help?
I’m confident once I get the correct part I’ll be able to put it in. I just ordered the owners manual.
Pics were not a lot of help. 1st shows no fuel pumps. 2nd shows all 3.
The pumps are thus:
1) lift pump. Does what a primer bulb does on a small outboard.
2) engine pulse pump. Driven by crankcase vacuum/pressure pulses. Maintains flow while engine is running.
3) injector high pressure pump. Inside the VST.
If #1, I bought mine from Rock Auto for $40. It is a generic MARINE fuel pump.
Ok, yeah my rookiness is burning through pretty hard here....
So I hear the pump with the ignition come on.
So it must be number 2 or 3, potentially both? I have a manual coming . I’ll run some diagnostics to narrow things down.
Thank you!
Thank you!
Hey thanks! I already ordered it. Should be here today. Thank you!!I can send you a PDF of the manual if you pm me your email address.
We replaced the guts of our lift pump.
Could you please send a PDF copy of the manual to neilp77@hotmail.comI can send you a PDF of the manual if you pm me your email address.
Could you please send a PDF copy of the manual to neilp77@hotmXxxxcom
Would be greatly appreciated thanks
Many thanks SeptemberC !Check your email.
Done. Please download the manual to your computer so I can remove it from my Dropbox.Could you send me that also please
dtmoss300@yahoo.com
We have some but yes, unfortunately many are being discontinued.I do see parts on EBAY and some on SEADOO WAREHOUSE...praying there are other resources who can keep these repaired and running.
I am new to the forum. 70% sure I want to buy a Sea Doo Challenger but 90% sure I want the Mercruiser. I know they are not made anymore but after looking at this forum seems like u can find them but expensive. Please, I will take any feedback you would have... especially what to look for as a check list ? Looking at a 2002 right now... an XP and another possibly an SE. need to know when to walk away: I will do a lake trial.
