The boat is a 2004 Sportster LE DI (951cc)
Boat start and idle perfectly. Out of the water reach max RPM no problems but running a bit rough.
In water, can't get past like 5mph, engine sounds like it miss and cut at like 3500-4000RPM and can't get it higher than that. Can't get the boat on a plane. No audio beeps. One day it worked perfectly, the next day it struggled a lot to get on a plane. Now there is just no way to get it on a plane.
- Brand new wear ring/impeller installed by dealer.
- Got the computer checked for codes, nothing. Dealer said the engine seems to be running good (they did not test the boat in water)
- New rings on pistons, compression is like new.
- New coils installed.
- Changed spark plugs.
- Voltage is OK (14V when started, changed rectifier last year)
- Fuel pressure (tested just before the injectors) is above 100psi.
- RAVE valves cleaned.
- No beeps.
The way I see it, the problem occur when the engine in under load (in the water). Out of the water it runs freely up to max RPM (around 8000). Missfire? Not enough air? Not enough gas? Could the exhaust be clogged? Sensors? (What kind of sensors are in that boat?) Reeds? (what are the wymptoms of bad reeds?)
I have put over 50 hours of work trying to find the problem, I am so desperate
Any ideas before I get it back to the dealer? Thanks!
- No beeps.
