slidecatty
New to the site. thanks for the welcome.
I own a 2000 GTX with original impeller and wear ring. Last season ( from Colorado) I sucked up a good sized rock which not only gouged up my worn wear ring but also took a 1/2" x 1/4" chunk out of a plastic spline/ fin on the pump itself, impeller seems ok though. From that point on i've lost substantial low end. My question is after replacing the wear ring and using original impeller with proper clearance will I regain my low end without addressing the dinged spline/ fin?
Also I've noticed silicone being used instead of the multiple types of locktite . Must this be a marine silicone or can any type be used?
Thanks for the help!
