What does everyone recommend for sealing the jet pump to the ride shoe silicon sealant or the neoprene rubber seal? What about sealing the jet pump to the venturi can a little silicon sealant be used there as well? This is for a 97 GTS, Thanks.
the jet pump to the pump shoe should only need a NEW neoprene seal. You can seal the upper part of the pump to the hull where the 2-bilge(s) and water line is with RTV silicone.and around the ears where the bolt bosses are that bolt to the hull to prevent air from sucking/siphoning in and causing cavitation.
