busterthejetboater
Hi all
I am in the process of rebuilding my jet pump as fitted to a Mercury 240efi. I am now stuck as I do not have the Pinion Gear Location Tool 91-831897. My pump housing has been powder coated (big mistake!) and I have fitted new bearings.
Now I presume that the shimming process for the pinion shaft assembly is to set the height so that the gears engage fully over the whole length of the teeth and not too high or too low. The shimming of the matching impeller shaft drive gear is to set the load on the gears?
Does anybody know of a tool that I can hire or buy at a good price? Looking on the net the cheapest is around US$150 excluding shipping to Australia. Is there perhaps another way of doing this?
I was thinking of firstly installing the impeller shaft, gear and bearing assy and then use a height gauge measuring from the pinion housing mount flange on the main jet drive housing down to a point on the impeller gear teeth. Then by measuring from the same point on the pinion shaft gear to the bottom of the pinion shaft housing the difference would be the required shims?
Any help would be greatly appreciated.
