1983
-Whats up guys? Finally got the carbs dialed in and ski runs and starts great :thumbsup:
-Current issue is I could get 55 mph out of it a couple months back, now only able to get ~52mph. This is on GPS. Its not a huge concern but would like to be back to at least the 55mph.
-I have a tiny tach on order so I do not know the current max rpm.
-151 psi mag and 153 pto compression numbers and 1 turn out low speed needle , and 0 turns out high speed settings on carb. Everything has been gone through on this ski and is up to par. Fuel system, filters, carb rebuilds complete with needles and seats, all fuel hoses etc. Another note, the carbs butterfly's are opening fully at WOT. I have checked that many times as I recently installed a finger throttle.
-Take a look at these RAVE valve pics. They are spitting oil, and leaking it down side of engine block. The bellows are blown I know. They do have some side to side movement so I know they are worn out. I have already pulled a good set of non-leaking complete RAVE valves from my 96' GSX 787 parts ski. I will be cleaning those valves and installing them in my XP. Both sets do have the green bellows but of course the XP ones are shot.
-Is there anything else I can look at to get my top end MPH up?
-Rob
-Rob
