Dirtrover
Probably have to clearance the new wear ring if the starter can't overcome the friction, is there any lube on the inside of the wear ring to help the starter out? Those impellers will rub on their new wear rings at first, which is what makes some aftermarket brands more friendly than others.
This actually worked. The impeller spins much better. Still drags a little, but it seems usable now. So, I did get an OEM neoprene ring, do I have to put the ultra black on it...really don't want too. What is the torque spec for the 4 bolts on the pump, can't seem to find it in the manual.
Sent via carrier pigeon
