I figured out my starting issue on water when hot!!!!!!!
The water regulator was allowing water to dribble into the resonator. And the main hose from the pump was also contributing.
A guy got stuck at the dock, and since I couldn't start the boat I was stuck with him blocked in. I took that time to track down the dribbling sound. I had hose clamps with me so I clamped off both the water regulator water hoses as well as the main water hose from the pump.
I then was like, screw it lets try to start with the hose clamps on and sure enough it fired up with no issues whatsoever! It was absolutely refusing to start the entire time until I clamped off those hoses and it fired up instantly!!! Of course I immediately shut it off since I wasn't going to run without water circulating. I took the clamps off and it fired up without issue!
I figured out why it wasn't starting! Now, I need to figure out why these hoses are causing this.
QUESTIONS:
Is the water regulator supposed to dribble water into the resonator while the boat sits?
Is the main water hose supposed to be held up and not laying in the hull?
Is there some valve or anything that should prevent water from bogging the exhaust out when sitting in water?
Any advice on how the hoses are supposed to be routed or if they're supposed to be elevated would be great. But at least now I know the cause!
I'm sooo stoked man you have no idea. I've been fighting with this issue for a very long time!
