Is This Cheap Walmart Compression Gauge Good Enough?
I bought a cheap 40$ one last month and it was 10% off scale (it was telling me I had 135 instead of 149). It took a 400$ gauge to really know what was going on.
Benji.
I have one of the actron gauges from Autozone. I think it was about $30 and has always been accurate.
auto parts houses 'rents' tools Rent 2or3 and average them should be pretty accurate
Frank_Hassa, no, a cheap Wal-mart one is not good enough, you need what I've got, a cheap Harbor Freight one :)
I bought a "Lisle 20250 Compression Tester" and it was horrible. At 135, I was almost ready to cry after replacing my engine last year. But it was actually at 149 with a professional tester.
Benji.
The most important information that a cheap compression tester will give you is this: Cylinder compression consistency.
I get the concept but do not know why it's important nor a method for testing. Are you comparing cold cylinders to hot? From one stroke to the next? From one day to the next? Etc... I don't see how a cylinder can be "inconsistent" in the 1st place. The pieces and parts are all the same from one stroke to the next, so what changes?
And if a cylinder's compression is inconsistent, what problem would cause it? Say you had an inconsistent reading. What would be the problem, and what would be the solution?
By consistency here we are speaking of between cylinders, not between tests of the same cylinder. I believe the number from the experts here is to have the cylinders read within 10% of each other.
We generally test with cold engine, throttle wide open.
As stated above, recommend testing with 2 different testers, especially before doing something major based on compression; I have 3.
Hope this helps a little.
