henryb
I've noticed that my boat has encountered a variety of electrical problems that all seem to come and go intermittently. Some of which go away and have not come back?
I have a theory that I may have introduced these issues myself... Not knowingly... But I have taken a few steps that I hope to confirm may solve this problem.
My old battery seemed to be nearing the end of its days, so I've had to put it on a trickle charger, basically any day that the boat is not getting used, otherwise it won't have enough juice to start the engine.
Now this trickle charger has its own shutoff mechanism. So it should be safe or so I thought? Now, where I connected the charger to was one of the 12v access ports (ie cigarette lighter ports)... Since the wall socket in my boathouse was right near the glove box... I used the one that is near the radio in the glove box.
Now my theory was that this 12v cig lighter access port would eventually lead back to the battery... and thus it would charge up the battery on a trickle! And it did seem to work? But my new theory is that this charging path may be the cause of many of these intermittent electrical problems, with voltage going to a number of systems... Sort of through the back door, if you will and causing them to behave in an unexpected manner?
I'm not sure if that is really the case, but these are the steps that I am taking to prove my theory:
1. Bought a new Marine Battery (800 CA)
2. Stop doing the trickle charging through the 12v access port.
3. Turning off the main electric knob on days when the boat does not get used.
If the battery ever does drain down, I will charge it directly on its posts, with the main electric knob turned off.
