One per head....
So, I was right. You have a nipple for each side. The problem is you have no initial cooling across the top of the head for helping to prevent detonation.
You cannot use those nipples as inlets. I guess you could but you would be running your cooling system backwards.
If you put water in from the top of those nipples, you will not know if your cooling system stays flooded because at the bottom of each cylinder, you have a drain line. It's located at the bottom of your cylinders on the port side. If your exhaust manifold is on, you might not see it. But, you might be able to look down between them to see the line I'm referring to. This line comes out the back side and connects to your exhaust system, just before exiting the hull.
If you push water down across the top of that head, you have to overcome that drain, then fill the bottom of the cylinder to the point water dumped out and over the top of your exhaust loop, where your pee line connects to. Then, once the water dumps over the top of that pipe, it'll come out that 1/2" nipple half way down the tuned pipe.
What's wrong with that? The normal flow of water for the 787 is to preheat the tops of your cylinder heads, since they see the most temperature at startup. Then, the water crosses over to the tuned pipe for pre-heating before going into the bottom of your cylinders. The water is then pushed up to the top of the head, then out the nipple on the starboard side and out of the boat/ski. Without running that water through the tuned pipe, your resonance is going to change. That affects the performance of the motor.
The idea of water flow in our motors is that the pump "pushes" the water up and through the cylinder head.
In your layout now, the water would come in through the top and fall to the bottom of the cylinder, where the water outlet also is. This can leave pockets of air inside the casing.......
The head looks cool but I don't think I'd like the idea of using something that didn't follow the standard water flow guidelines............:cheers:
