artur3910
Hi every one. I have some problem with ingington timing.
My question is
1. " is timing have to stay the same on any RPM? "
When I check with the timing light, on idle speed is ok, but when I press throttle is going off from the mark to advance.
Is this timing don't have to be same on any RPM?
I have sea doo 3D RFI ,
When I put it on water don't have power, going only maybe 15-20 mi/hr and I can't get Max RPM, no meter how much I press throttle. Some times is like shooting some power but only for 1 s. Then again is so slow.
But on trailer and off the water engine run perfect. Also I put new spark plugs, after running engine about 20 on water they a so black dark,and they stop working, I have to put new again .
2.Is this ingington timing problem?
My question is
