Info Gauge Replacement Require Cover Removal? 2000 RX
bd2000rx
Question in title: Does Info Gauge Replacement Require Front Cover Removal on a 2000 RX? It is carb'd if that makes a difference.
I did initial troubleshooting and determined gauge is faulty. I
got a replacement and need to fish the wire to the MPEM through the front of the front cover, but the MPEM plug is large and square and I don't think can be fished/pulled through the cable routing. From what I can tell the only way to do it will be to remove the front hood cover - shop manual shows it is a lot of screws to remove from underneath. Is there a trick or a better way other than removing the top cover of the front hood?
It is not that hard to remove the cover on the hood. Id do it the right way if I were you.
Thank you, I'll do that I just want to confirm what the right way is. Remove all the screws listed here? In the diagram, the screws that say 3 N*m
Id recommend to keep the actual hood on and just remove the cover. Take all the screws out listed as 3 Nm.
Thank you very much. I'll respond back here with how it goes to help out anyone in a similar situation if anyone ever googles it.
I wanted to ask because I'm not experienced, didn't know if there were any tips or tricks. I've done a ton of crap without experience and after the fact someone said 'all ya had to do was...' which woulda saved me time, so figured I'd ask first.
I did have to remove part of the hydraulic bar that holds the hood open as it runs through same hole that the info gauge wire runs through. The hole is not big enough for the mpem plug to fit through while the bar is in place.
You need to remove the plastic plug so it is just the wires.
You can buy the tool very cheap.
Amazon.com
Thanks for the reply! I don't think that is the fix here.
I could remove the wires from the plug but I think that could be messier than removing the cover:
Just to be clear, I'm talking about the info gauge (item 46 below), not the speedo gauge (item 17 below).
Connector 54 (mpem "AMP Plug" connector type) is what is causing the problem: it is too big to fish through. The seadoo manual explains how to pull the wires from it but I think it would be messy. The tool you recommend would not help remove wires from the mpem connector - unless I'm wrong. Your tool would be used on "Packard Plug" connectors e.g. connector 47 or 19.
You can just remove the whole hood if it makes it easier, Even if it takes more time best way is the right way. I think it would be very messy to take all the wires out.
Making a follow up post to let folks know that it went great and to recap my symptoms and what I ran into in the process of fixing.
- Info gauge was giving chinese looking lettering after startup. I assumed this was due to low battery, as I was riding it went away so I assumed that confirmed it. Eventually the info gauge only displayed chinese lettering. Then finally was blank / didn't have any info at all, over a period of a month.
- There was some fog in the info gauge that indicated probably water got in it.
- Disconnecting black battery cable and using a tester light indicated a short
- Voltmeter confirmed power was getting to the (blank) info gauge.
- Thus I bought a new (used) info gauge on Ebay. When it arrived, I jerry rigged it to get power to it to confirm that my old gauge was the problem: it worked (showed my fuel level, etc).
- As I said above and 2strokeboy confirmed, I needed to remove the "cover" off the "hood" to remove the old info gauge and route the wire for the new one. The reason is because the info gauge comes out toward you which means you need to undo the plug from the mpem and pull the plug and all the wire up through the cover. The plug is too big to allow this. Thus you need to remove the cover.
- I unscrewed all the screws (5.5mm head, needs deep socket. I used a 7/32" deep socket instead). There were also other things I needed to remove to allow the plug to fit. The diagram only shows one side of the ski (so actually need to double the amount of screws to remove) plus doesn't really show about 5 others at the front of the cover.
- The main problem I had was that the majority of the posts on the cover that the screws drive in to were broken. Maybe only 6 of the ~14 posts were not broken. I know I broke one of them but the others were already broken as if someone had been in there before and broke them. There was other evidence that this was the case. I'm second owner but have owned for 12+ yrs.
- Epoxy/jbweld the broken posts back into place seemed to do the trick.
Here is what I ultimately needed to do:
-Cover (pink arrow) needed to come off of the hood (blue arrow). Hood stayed attached the whole time.
-Everything in green needed to come off to allow the cover to come off and allow the wire for the gauge to be routed through the fiberglass hole.
- Basically all the 3-N*m screws and then part of the hydraulic arm to hold the hood up to get it out of the way of the plug.
- The green/orange box is where there were an additional 5 3-N*m screws that I don't think are labeled here. I saw 4 of them but there is one at the very tip of the cover that I missed and snapped the post while removing.
