impeller oil
bigJake
Manual says:
"Lubricant in impeller shaft reservoir should be
drained. Reservoir should be cleaned and refilled
with SEA-DOO synthetic 75W90 GL5 polyolester
oil."
West Marine has a synthetic 80W90 gear lube. Can this be used? if not where can I get the Sea-Doo oil or another brand that can be used?
Same stuff...
that'll work boss...I use the Mobil Syn 75/90 from Autozone/Walmart.
I use this same stuff timmyboy uses. Yeah, it's a lot cheaper at Advanced Auto parts, where I buy it from.
I'm not going to say I don't use West Marine, I only use them as a last resort because there are some things that you just can't buy at Walmart.......:rofl:
