I would guess that these nicks in the leading edge's would cause cavitation and can any one advise if the drive shaft protector needs to be straight. You can see that it is set off to one side.
I plan on pulling the pump for a bearing rebuild and looking at installing a swirl impeller as I'm have a spinning issue under load. Where and how do you measure the wear ring?
get that blue thing off of there. I can't imagine how much HP that wastes. I've never even heard of a drive shaft protector, let alone driveshaft damage.. and I've owned ski's since 1993.
