knee-dragger777
Ok
new to forum, and I have searched on here, but to no avial.
Is there a comprehensive tool/website that anyone has found to help with part numbers for Impellers? I have a '96 GSX and plan to replace the wear ring as part of its winterization, and I think my impeller has some major nicks. I thought I might do a little searching for a possible cheap (< $175) replacement.
The problem is, I just don't have enough good information to make a determination.
Here is what I know--800CC engine.---stock impeller 17/24& 16/23 (Pitch & diameter?)
140mm factory pump (is this the length? I think the diameter)
271000660(factory OEM Part number?)
Is there a one spot shop to understand aftermarket (Solas/Nujet), part numbers for my application?
Thanks,
Thanks,
