Impeller cover removal
justmike
I have a 2002 GTI-LE... What all is involved in removing the impeller cover? Water is seeping in and I want to remove the cover and re-seal it with a marine sealant. How big of a problem am I getting into and is there a certain kind of sealant or sealants I should use? ( I am in NO way a mechanic).
Thanks for any and all help.
Do you have a seadoo shop Manual? You could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
This might be the best $10.95 you ever spent. I bought a paper back manual from a seadoo dealer and it cost me $85.00.
Karl
