thanks I'm going to checkout that stainless steel refurb. I wish I knew there were other options on the impeller. I'm sure there will be a next time. But with the new impeller I see a good performance improvement so the family is all happy.
Ibjeepin I don't know if they replaced that. I'm going to call and ask the mechanic.
Thanks,
I ordered the bushings figuring I might need them but after disassembly I looked at the way the bushings were pressed into the stator. And the manual is as little help with much more than "remove the stator" I thought otherwise as there is a double bushing requiring a deep or long puller to remove. Mine looked ok so I replaced only the seal and the seal protector only.
FYI
I took the Doo out on Lake Ontario today with 6 foot+ rollers so the run was not 100% conclusive as I could not do any speed tests
