I have a 1992 seadoo gtx with the white rotax 587. I was just given the ski by my grandpa. It died on the lake about 4 years ago. It’s sat since. When I got it I pulled the carbs and rebuilt them. Pulled the tank and the pickup tubes inside the tank had disintegrated. Replaced tubes. Fuel filter and 2 stroke oil filter. Took it out for a ride and it ran great for about 10-15 minutes then died. Kinda sounded like it didn’t have fuel. Just bogged out. Fired right back up went about 25 yards then bogged out again. I can’t figure this out. Had it out 2 times since does the same thing. Runs great for about 10-15 minutes and then dies. It will fire right back up after every time it dies. Thought it was maybe overheating but after running it hard for about 10 minutes the whole engine only ranges from 140-150. Doesn’t have the old grey fuel lines. I’m lost on it
New parts-
Rectifier
Fuel filter
Oil filter
Spark plugs
Carbs just rebuilt with genuine Mikuni rebuild kits
Fuel tank flushed and refilled with high test
All cooling lines flushed and cleaned thoroughly
ON THE WAY BUT NOT INSTALLED-
Fuel valve petcock for the fuel/reserve/shut off
New parts-
Rectifier
Fuel filter
Oil filter
Spark plugs
